Pick-and-place unit
Nov. 1, 2011
The PPU-P offers up to 120 cycles/min and includes a valve-control unit that actuates the gripper connected to the PPU-P when placed directly over the individual target position.
Features & benefits
  • Unlike pneumatic units, horizontal and vertical motion overlap and are positively driven by a curved roller, reducing cycle time by one-third
  • 145-mm horizontal stroke, 45-mm (20-mm linear) vertical stroke, 1-kg moving mass; cycle time of 0.63 sec; 2 × 50-msec gripping time
  • Horizontal stroke can be adjusted by up to 12 mm/side to balance build-up tolerances; end positions can be adjusted by 15 mm, independent from each other; differences in height between mounting and depositing position can be balanced without an intermediate stop
Schunk Inc.
(919) 572-2705
schunk.com/schunk/index.html?country=USA
Clean. Compact. Less heat.
April 16, 2025
