Braid-reinforced hose
Flexible Silbrade silicone hose can be used in fluid applications and as protective jacketing
March 1, 2010
Flexible Silbrade silicone hose can be used in fluid applications and as protective jacketing.
Features & benefits
  • Open mesh polyester braiding reinforces walls of silicone tubing — handles high pressure and temperatures from -80° to 350° F
  • Tight bend radii and restricted space usage without impeding flow
    • Peroxide-cured Silbrade; nine sizes from ⅛ through 1-in. ID; custom units available, including cut-to-length pieces, colors, and hardnesses
NewAge Industries Inc.
(800) 506-3924
www.newageindustries.com
