Case-hardened rack
The Performance Class Rack is a case-hardened rack series that pairs the rack with a gearbox actuator and pinion for system efficiency and optimal performance.
Features & benefits
  • Four series available: Value, Smart, Premium, and Performance Class
  • Value Class for low-duty applications; Smart Class for mounting flexibility; Premium Class for high-duty applications
  • Performance Class is case-hardened for optimal performance; available in two options — Performance (standard hole pattern) and High Performance (optimized hole pattern for high feeding forces)
Wittenstein Inc.
(888) 534-1222
wittenstein-us.com
