Right-angle gearboxes
IEC right-angle (RA) gearboxes feature a symmetrical hollow output shaft for right, left, or dual-shaft configurations.
Features & benefits
Nine sizes from 26 to 130 mm; RA26 through 90 have compact die-cast aluminum housings for heat dissipation, and maximum torque output; RA110 and RA130 are cast iron; powder-coated housings resist corrosion
0.06 to 7.5 kW, 1/15 to 10 hp input power; 10 to 1,050 Nm, 5 to 10,000 lb-in. torque; foot, flange, shaft mounting
Optional torque arm; IEC input flanges; synthetic long-life lubrication on RA26 to 90
Symmetrical output shaft facilitates mounting and plug-in shafts for easy assembly
Groschopp Inc.
(800) 829-4135
www.groschopp.com
Circle 171
