Sealed clutches
Model HC/CH clutches for marine applications feature a key seal that allows use of standard O-rings and makes installation in current configurations easier with a double keyway and single drilled actuation hole.
Features & benefits
Key seal simplifies sealing and minimizes damage to expensive seal arrangements
Forced oil-cooling provisions for high-energy engagements
Disc-Pac cores feature heavy plate thicknesses to maximize torque and heat capacity while minimizing spline wear to disc cores and hub; alloy steel hubs feature induction-hardened teeth for maximum spline life
EWA model for oil-immersed applications; EDA units can run as dry friction clutches
Industrial Clutch
(262) 547-3357
indclutch.com
