Linear actuator with RS-485 protocol
The Idea line of programmable linear actuators now features a RoHS-compliant electronic drive and fully programmable control unit integrated with a linear actuator.
Features & benefits
Small footprint
RS-485 protocol allows long data transmissions with immunity to electrical noise; uses differential signal lines for limiting common-mode noise
Twisted-pair cabling for cancelling induced noise current; allows communication over 1,000-ft network without termination resistors — to up to 256 addressable device nodes
Industrial controller sends commands to all drives at once or control each drive separately
Programmable current control, single 12 to 48 Vdc supply voltage; inputs rated for 5 to 24 Vdc
Haydon Kerk Motion Solutions
(203) 756-7441
idea-drive.com
