The BRECOprotect timing belt offers stiffness and accuracy of carbon-steel cords fully encapsulated in a special hydrolysis-resistant blue polyurethane. The FDA-approved AU1 polyurethane resists water absorption, making it suitable for wash-down machinery with water-based detergents. Belt stiffness resulting in high positional accuracy, high tooth-shear strength, and stable length tolerance and pretension under varying humidity conditions make the belt suited for linear drives and conveyors operating with food-processing and wash-down applications. The belts are also grease and oil resistant.BRECOflex Co. LLC, 222 Industrial Way West, Eatontown, NJ 07724, (888) 463-1400, www.brecoflex.com
