PressPhoto-StepperKits-Posital
Magnetic Encoder Provies Absolute Position Feedback
Aug. 9, 2019
The new magnetic encoders from Posital  provide absolute position feedback They are available with multi-turn measurement ranges which can be useful when a motor is connected to a screw shaft, cable drum, or gear-reduction system. The multi-turn rotation counter is self-powered, using Posital’s Wiegand energy harvesting technology. The rotation count is always up-to-date, even if the machine has moved while control power was out. No backup batteries are required.  The encoders for stepper motors are “kit” or modular devices, designed to be added into a motor housing and measuring the rotary position directly from the drive shaft. Kit packages are available with the same mounting form factor as popular incremental encoders for NEMA-standard stepper motors. That makes these encoders drop-in replacements for less advanced incremental encoders. The magnetic measurement module is measures 37-mm in diameter and are 23-mm thick. They resist dust, moisture, and shock/vibration loading. Shields are available to protect the measurement module from external magnetic fields. SSI and the more advanced "BiSS C" communication interfaces have been implemented. Both are open-source interfaces compatible with a range of PLC’s and computers.
Posital Fraba: www.posital.com/en
Get better products to market faster. This e-book reveals how industry leaders are adopting an agile approach to product development with integrated design and collaboration software...
Aug. 7, 2025
Change is difficult, but with the right plan, it can be successful. Learn from Rathbane Group's transition from 2D to 3D and their strategies for leveraging efficiencies and mediating...
Aug. 7, 2025
Discover how the Autodesk Platform helps you embrace a cloud-first evolution in design and manufacturing, connecting your data and unleashing your agility with AI-powered insights...
Aug. 7, 2025
Discover how Autodesk Fusion can improve collaboration, automate repetitive tasks, and eliminate waste to shorten your product development lifecycle.
