DoE Builds Large-Scale Quantum Network Testbed
Scientists from the DoE’s Brookhaven National Laboratory and Energy Sciences Network (ESnet) and Stony Brook University have been working on an experiment that keeps U.S. quantum networking research on the international map. They have built a quantum-network testbed that connects several buildings on the Brookhaven Lab campus using portable quantum entanglement sources and an existing ESnet communications fiber network—a significant step toward building a large-scale quantum network that can transmit information over long distances.
“In quantum mechanics, the physical properties of entangled particles remain associated, even when separated by vast distances,” says Kerstin Kleese van Dam, director of Brookhaven Lab’s Computational Science Initiative. ”Thus, when measurements are performed on one side, it also affects the other. To date, this work has been successfully demonstrated with entangled photons separated by approximately 11 miles. This is one of the largest quantum entanglement distribution networks in the world, and the longest-distance entanglement experiment in the U.S.”
One distinct aspect of the team’s work that sets it apart from quantum networks being run in China and Europe is that the entanglement sources are portable and can be easily mounted in standard data center computer server racks connected to regular fiber-distribution panels.
The team successfully installed a portable quantum-entangled photon source in a server rack housed within the BNL Scientific Data and Computing Center, where the lab’s central networking hub is located.
With this connectivity, entangled photons now can be distributed to every building on the Lab’s campus over Brookhaven and ESnet fiber infrastructure. ESnet’s fibers have been placed along paths between buildings to enable the distribution and study of entanglement over increasingly longer distances. The portable entanglement sources also are compatible with existing quantum memories (atom-filled glass cells that can store quantum information). Normally kept at super-cold temperatures, these cells can be stimulated using lasers to control the atomic states within them.
The Brookhaven-testbed features portable quantum memories that operate at room temperature. Such memories, engineered for quantum networking on a large scale, have been a longtime “pet project” for Eden Figueroa, a joint appointee with Brookhaven’s CSI and Instrumentation Division and a Stony Brook University professor who leads its Quantum Information Technology group. He serves as lead investigator of the quantum networking testbed project.
“The demonstration aims to combine entanglement with compatible atomic quantum memories,” Figueroa says “Our quantum memories have the advantage of operating at room temperature rather than requiring subfreezing cold. This makes it natural to expand the test to principles of quantum repeaters, which are the technological keys to quantum communication over hundreds of kilometers.”
Quantum networks send light pulses (photons) through the fiber, which requires the light to be periodically amplified as it travels through the lines. However, unlike digital transmissions in communication networks, quantum entanglement is limited by decoherence, where entangled photons, for example, revert to classical states because interactions with the environment make them lose the ability to remain entangled. This limits these fragile quantum states from being sent over large distances.
Viable quantum repeaters will let Figueroa and his team scale up ongoing experiments within “local-area” quantum networks to a distributed, or “wide-area,” version. In anticipation of this, the team is building the necessary optical connections to link Brookhaven Lab’s quantum network to ones at Stony Brook and Yale universities.
“The quantum network with entangled photon sources mounted in server racks, portable quantum memories, and operable repeaters will mark the first real quantum communication network in the world that truly connects quantum computing processors and memories using photonic quantum entanglement,” Figueroa says. “It will mark a sea change in communications that can impact the world.”
