ARM Automation
More Info on ARM Automation
ARM Automation’s SplashBotix division provides creatives and owners in the automated fountain and aquatic show system industry with controls products and engineered solutions that enable new design possibilities, reduce risk, shorten project timelines and lower net costs for both startup and long-term ownership.
Inspired by parent ARM Automation’s 15+ years of experience building industry-leading aquatic show systems, SplashBotix’s controls and automation solutions aim to offer reliability across systems of every size and level of complexity.
Visit www.splashbotix.com to learn more.
Videos
Made with Adobe Express
Future of Aquatic Robotics
Understand how ARM Automation integrates magnetic coupling and embedded control systems to enhance safety and durability in machine design. See what you retained with a knowledge...
By storing and releasing energy through capacitors, SplashValve minimizes peak current draw while maintaining precise valve actuation. Low-voltage operation, capacitor bursts ...
Discover how ARM Automation’s SplashValve delivers maintenance-free operation through advanced materials, rigorous testing, and a “set-and-forget” design philosophy.
Spool Valve & Fluid Control
SplashValve combines mechanical finesse with magnetic coupling for proportional motion. Precision-lapped stainless steel and Kevlar belts help keep performance rock-solid under...
Dynamic shaft seals often fail in submersible systems, but the SplashValve eliminates seals entirely—using magnetic coupling for torque transfer through a sealed housing. Take...
Articles
Discover how the SplashValve’s servo-driven magnetic system delivers precise water modulation without mechanical wear or leakage.
ARM Automation Categories
Request More Information From ARM Automation
Additional content from ARM Automation
Designing for Underwater Life
SplashValve redefines underwater automation with a corrosion-proof housing built for years of submersion, high flow and zero maintenance. Pay attention, because at the end of ...
