True Gear & Spline
1629 Industrial Rd,
Cambridge, ON N3H 5G7
Canada
519-653-1301
More Info on True Gear & Spline
True Gear & Spline is a Canadian precision machining company specializing in custom gears, splines, CNC machining, and power transmission components for automotive, aerospace, mining, and industrial applications.
Products
Courtesy of True Gear & Spline
Gear Coupling
True Gear & Spline manufactures precision gear couplings for industrial power transmission applications. Gear couplings provide a flexible mechanical connection between shafts...
Bevel Gears
True Gear & Spline manufactures precision bevel gears for power transmission applications requiring changes in shaft direction. The company produces custom bevel gears using...
Splines
True Gear & Spline manufactures precision splines for power transmission and mechanical applications. Its spline capabilities include straight-sided, involute, and serration...
Sleeve Coupling
True Gear & Spline manufactures precision sleeve couplings for industrial power transmission applications. Designed to connect shafts and transmit torque, sleeve couplings...
Spur and Helical Gears
True Gear & Spline manufactures precision spur and helical gears for demanding industrial applications. The company provides custom gear manufacturing using advanced CNC machining...
Request More Information From True Gear & Spline
