Positioning with accuracy and strength
Speeds can be as high as 200 mm/sec, with accelerations up to 0.1 m/sec″. The unit has a relatively small footprint of 199 199 mm, and a 32-mm height. The drive mechanism for each axis, a precision preloaded miniature ball screw coupled to a dc motor and encoder, is inside the stage. The frame is high-strength anodized aluminum, and the ent ire device weighs about 5.5 lb. It handles loads up to 50 N.
The standard model includes backlash- free preloaded cross roller bearings and a 90-mm square hole in the middle to let light or objects pass through the center of travel.
