Product Spotlight: Tapered-Roller Bearings
The cone, cup, and rollers (cone assembly) carry the load while the cage spaces and retains the rollers on the cone. Through-hardened bearings are standard and casehardened bearings are available.
Through-hardened bearings have a consistent hardness throughout the component while case-hardened bearings have surface hardening combined with a tough, flexible core.
The bearings offer dimensional stability under heavy loads, long life in harsh and contaminated environments, and a durable steel cage.
They are dimensionally interchangeable with other bearing products.
Standard stock sizes include 15 to 240-mm (0.59 to 9.45-in.) ID to 35 to 40-mm (1.38 to 15.75-in.) OD.
AST Bearings LLC
115 Main Rd.
Montville, NJ 077045
(800) 526-1250
astbearings.com
