Heat-Resistant Hose
Two new products, MegaSys M3KH and M4KH wire-braid hoses, are rated for pressures of 3,000 and 4,000 psi, respectively, in all sizes. A 250°F service rating exceeds SAE requirement of 212°F, so the products suit mobile equipment where high temperatures result from smaller reservoirs and high velocity and pressure fluids. Both hoses are available with MegaTuff covers that reportedly last up to 300 times longer than standard hose operating in abrasive conditions.
Gates Corp.
1551 Wewatta St., Denver, CO 80202
(303) 744-1911
gates.com/megasys
