PTFE-composite bearing material
Meco 3000 is a for chemical environments.
Meco 3000 is a for chemical environments. The material from Woodex Bearing Co. Inc., Georgetown, Maine, features a low coefficient of friction, high-temperature capability, and high-compressive strength. Its lubricity is good for dry-running applications where lubricant contamination is a concern.
