Flow-Rate Sensors
FTB2000 Series Hall-effect turbine flow-rate sensors can be used for OEM applications involving low-flow liquid monitoring. The sensors from Omega Engineering, Stamford, Conn., have 0.5% repeatability and measure flow rates from 0.13 to 7.9 gpm. Turbine operation is not affected by pressure changes resulting from aging filters.
