Mobile Controls
They control, monitor, and measure loads on cranes and construction machinery. The systems support CANopen as a sensor/actuator bus as well as industrial Ethernet as a fast data bus, and readily integrate in mobile applications. Thus, they can network different controllers or intelligent sensors with each other. Applications are written in C language or CoDeSys IEC 61131-3 PLC programming software from 3S Software. Proportional valves without additional amplifiers can link directly via integrated I/Os such as controlled PWM outputs.
Hirschmann Automation and Control
1540 Orchard Dr., Chambersburg, PA 17201
(717) 263-7655
hirschmann-usa.com
