Looking Back 06/10/2010
June 8, 2010
The world’s smallest automotive relay, the G8N from Omron Automotive Electronics, Farmington Hills, Mich., is one-half the size and two-thirds the weight of the company’s current miniaturized relay
10 YEARS AGO — 2000
Miniature relay fit for auto applications: The world’s smallest automotive relay, the G8N from Omron Automotive Electronics, Farmington Hills, Mich., is one-half the size and two-thirds the weight of the company’s current miniaturized relay. It can handle power-window motors, door locks, horns, wiper motors, and is suitable for smart-junction-box and module applications. The 14-V, 15-A relay also reduces power consumption by 50%.
30 YEARS AGO — 1980
Testing fighter designs for lightning survivability: Statistics show that every all-weather aircraft is struck by lightning at least once during its lifetime. At McDonnell Aircraft, engineers test an all-weather fighter’s vulnerability by generating lightning and firing the bolts at precision model planes. Lightning can hit an aircraft with electric current as high as 200 kA and 100-MV bolt voltage. Laboratory-generated lightning strikes the wingtip of a scale model of an AV-8B fight-attack aircraft and flashes away from the model’s tail. Initial tests involve high-voltage bolts about 25 to 30-ft long to determine lightning “attachment points.” The lightning’s path along the aircraft is also tracked.
50 YEARS AGO — 1960
Glass fiber gets a shotgun wedding: A glass-fiber barrel is the extraordinary result of research into building a lighter gun. Five-hundred miles of glass fiber are wound onto a steel liner only 0.020 in. thick and fused with an epoxy resin. The barrel is twice as strong as steel, yet lighter. Winchester Western Div. claims their 6½-lb Model 59 semiautomatic shotgun (which also has an aluminum receiver) is easier to point than heavier-barreled guns though they say that it should not be used as a crowbar. Heat-insulating qualities of the barrel mean the hunter will neither burn his hands after rapid firing nor freeze them in cold weather.
Copyright 2010, Penton Media Inc. All rights reserved.
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
