Dc-dc converters
March 16, 2011
The DPX Series of DINrail- mount dc-dc converters mount to TS35/7.5 or TS35/15 DIN rails.
The DPX Series of DINrail- mount dc-dc converters mount to TS35/7.5 or TS35/15 DIN rails. The converters are available with both 2:1 and 4:1 input voltage ranges covering from 9.5 to 75 V, with 40 to 60-W output ratings. The units are available with single, dual, or triple outputs. Singleoutput models are available with output voltages of 5, 12, or 15 V; dual-output models have ±12 or ±15V outputs; and triple-output models provide a 5-V main with either ±12 or ±15-V outputs. The single-output models can be adjusted ±10% of its nominal output via a front-panel mounted potentiometer.
Additional features include reverse-input-polarity protection, remote on/off control, 16-kV input-to-output isolation, protection from overvoltage and overcurrent, are convection cooled, and operate over temperatures from –40 to 85°C.
TDK-Lambda Americas Inc.
3055 Del Sol Blvd.
San Diego, CA 92154
(619) 628-2859
www.us.tdk-lambda.com/lp/products/dpx-series.htm
© 2011 Penton Media, Inc.
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
