Limitations of epicyclic gears
At very high gear ratios the efficiency of compound epicyclic gears can be disappointingly low caused by power loss from tooth friction resulting from high meshing speeds and high tooth loads.
A reader recently requested a copy of this feature from our archives. You may also find it valuable. Click the image to view the full pdf.
