Push-Quick Fittings
Push-Quick fittings combine the quick, easy functionality of the Push-Quick Series with the flexibility and security of the MGQC Quick Connect line with no circuit interruption.
Sept. 2, 2004
The fittings can be used as a connection point for a temporary function or circuitry connection in applications such as airflow/pressure testing, valve dumping or venting, and as a quick connection to a valve, cylinder, or hose.
Clippard Instrument Laboratory Inc.,
7390 Colerain Rd., Cincinnati, OH 45239,
(513) 521-4261, www.clippard.com
