New Product: Double shut-off quick coupling
The minimum-spill, thread-to-connect S51 Series double shut-off quick coupling is designed for use with most industrial fluids.
The fluid-transfer coupling can be connected under full system pressure by rotating the female threaded heavy-duty ductile cast-iron wing nut or brass hex nut onto the mating male threaded tip.
The unit features a steel interchange and internal parts are brass and stainless steel with the body and top outer shells electroless-nickel-plated steel. A brass-body tip and poppet are combined with a steel valve for corrosion resistance. The coupling features minimum air inclusion during connection and minimum fluid spillage during disconnection.
SafeWay Hydraulics Inc., 4040 Norex Dr., Chaska, MN 55318, (952) 448-2600, safewayhyd.com
