The long fibers mechanically interlock which reduces warpage and shrinkage and absorbs higher stress levels. The 30% glass-filled compounds more than double the impact strength of short-fiber versions. Benefits include improved long-term creep and fatigue resistance, better dimensional stability at elevated temperatures, weight reduction, increased throughput, part consolidation, reduction of secondary processing, and improved chemical resistance.
RTP Co., 580 E. Front St., Winona, MN 55987, (507) 454-6900, rtpcompany.com
Aug. 21, 2025
