New Product: High-temperature IR thermometer
The IRtec P1600 IR thermometer measures from 1,100° to 2,900°F, and is available with twin green lasers for much higher spot visibility.
Jan. 24, 2008
It has a distance-to-spot ratio of 200:1, and accuracy is ± 0.5% of reading. It can store 500 readings, including actual, average, max, min, and change in temperature. Emissivity is adjustable. It has analog output and RS-232 PC communication, as well as programmable acoustic and visible alarms.
E Instruments Group, 172 Middletown Blvd., Suite B201, Langhorne, PA 19047, (215) 750-1212, www.einstrumentsgroup.com
