New Product: 16-Channel USB DAQ Uses BNCs
A low-latency, highly deterministic control output mode operates independently of the PC to let the digital, analog, and timer outputs respond to analog, digital, and counter inputs as fast as 2 μsec; at least 1,000 faster than PC-based USB DAQ products. Seven programmable input ranges span ±100 mV to ±10 V, full scale. An oversampling mode includes line-cycle rejection for low-level voltage measurements in the presence of ac-powerline noise. A 37-pin D-sub connector provides two 16-bit, 1-Msample/sec analog outputs and 16 digital I/O with a 4-MHz sample/update rate. Four counter inputs measure frequency, period, pulse width, or quadrature encoders up to 20 Msamples/sec.
Measurement Computing Corp.
10 Commerce Way
Norton, MA 02766
(508) 946-5100
mccdaq.com
