New Products: Proportional-Control Valve
The VED05M proportional-control valve with onboard electronic amplifier and Hall-effect spool position sensor is for closed-spool, inner-loop operation.
The amplifier is packaged within a fully potted, anodized-aluminum housing for IP65 protection. Valves ship with all setpoints factory preset to catalog specifications, allowing out-of-the-box installation and operation. Users can tailor settings to customer requirements through a Windowsbased GUI. The valves offer numerous spool-flow ranges, load-metering styles, and various spring center conditions, matching application requirements off-the-shelf without customization. All components are field replaceable.
Continental Hydraulics
(952) 895- 6400
continentalhydraulics.com
