Positioning Tables
A new family of the 402XE and 403XE linear-positioning tables comes packaged with motor and limit sensors included or can be ordered with mounting for other motors to meet specific requirements.
The steel "U" design allows for integration of the bearing and ball-screw nut. The 402XE comes in a 50-mm-wide footprint and, with the optional hardcover, increases to 57-mm wide. The 403XE is 60 mm and expands to 80-mm wide with the hardcover option.
Parker Hannifin Corp., Electromechanical Automation Div., 5500 Business Park Dr., Rohnert Park, CA 94928, (707) 584-7558, parkermotion.com
