DIN-Rail Stepper Drive
The DIN-Rail mountable GTS500 5-Phase Driver is operated from standard 24-Vdc power supplies and features power LED.
Ia features an auto current down, the option to set the driver at 0.75 or 1.4 A, a resolution switch to power the motor at full or half step, and a panel that provides users with signal inputs. The unit weighs 180-g and measures 50 x 81 mm.
Nyden Corp., 2610-B N. First St., San Jose, CA 95134, nyden.com
