Direct-Frequency Synthesizers
Customized direct-frequency synthesizers are available with auxiliary outputs and fixed frequency/single frequency options.
Units are available in 14 different ranges with frequency ranges from 0.1 to 40 MHz to 1 to 6,400 MHz with optional resolution (μ Hz to kHz). Switching time runs from 1 to 20 μsec.
Programmed Test Sources Inc., 9 Beaver Brook Rd., Littleton, MA 01460, (978) 486-3400, programmedtest.com
