With molded-in terminals and a silicone membrane for front-panel sealing, the 3500 Series toggle switch meets IP67 requirements for applications in heavy lifting equipment, auto sports, marine, and public-highway vehicles.
The silver-alloy contacts have an initial contact resistance of 10 m with ratings from 15 to 20 A and a 6,000-cycle minimum life. Insulation resistance is 100 M with a dielectric strength of 3,000 Vrms between terminals and frame. Case material is UL94-VO rated and comes with a variety of actuator finishes including a locking style. Solder-lug/quick-connect or screw-type terminals are available.
Apem Components Inc. 63 Neck Rd. Haverhill, MA 01835 (978) 372-1602 apem.com
