New Product: 12-Vdc Gearmotor
The reversible gearmotor’s output is 46 lb-in. continuous torque at 100 rpm and 89-lb-in. peak. The unit measures 2.14 7.2 in. and has a keyed output shaft of 12-mm diameter 25-mm long. The gearmotor mounts easily with four face-mount M5 threaded holes, equally spaced on a 40-mm-diameter B.C.
Midwest Motion Products,
10761 Ahern Ave. SE, Watertown, MN 55388,
(952) 955-2626,
midwestmotion.com
