The MMP-TM55 12-Vdc GPk52-046 gearmotor works with any 12-Vdc source and requires only 7.2 A to generate full load torque, thus promoting battery life, quiet operation, and less-expensive drive electronics.
The reversible gearmotor’s output is 46 lb-in. continuous torque at 100 rpm and 89-lb-in. peak. The unit measures 2.14 7.2 in. and has a keyed output shaft of 12-mm diameter 25-mm long. The gearmotor mounts easily with four face-mount M5 threaded holes, equally spaced on a 40-mm-diameter B.C.
