1-MM Vacuum Cups
New SM Series vacuum cups are designed for pick-and-place applications. Standard cups are molded neoprene.
Also available are blue silicone rated to 200°C; and white-tempered silicone for food-handling applications. Cup diameters range from 1 to 130 mm, and toroidal, oval, bellow, and knobbed designs are also offered. An optional vacuum-cup mount with built-in venturi vacuum generator eliminates the need for a separate vacuum pump and results in a compact, reliable unit requiring only compressed air to operate.
Techno-Sommer Automatic,
2101 Jericho Turnpike, New Hyde Park, NY 11042,
(516) 328-3970, techno-sommer.com
