New Product: 1-kW Power Supplies
These supplies meet SEMI F47 power line sag specs, mandatory for high-volume semiconductor and integrated-circuit (IC) manufacturing equipment. The units are available in 10 nominal output voltages including: 3.3, 5, 6, 7.5, 12, 15, 24, 36, 48 and 60 V. In addition, most models can be adjusted up to ±20% of nominal voltage to accommodate nonstandard system voltages. The 7 through 60-V models have a peak power rating of up to 1.2 kW when operated with a line voltage of 200 Vac or higher. The supplies accept a range of input voltages from 85 to 265 Vac and comply with the EN61000-3-2 power factor and harmonic correction standards. Remote On/Off, DC Good and single-wire Current-Share signals are standard.
Lambda Americas unit of TDK Corp., 3055 Del Sol Blvd., San Diego, CA 92154, (800) LAMBDA-4, lambdapower.com
