New Product: Block I/Os
The Sercos III Block I/O digital device has 16 fast digital inputs and 15 combined fast inputs or outputs. Each single channel can be used both as input or output.
Nov. 8, 2007
The Sercos III Block I/O Analog has four inputs and two outputs that can be configured individually. The four inputs allow differential registration of analog current and/or voltage signals or the detection of temperature signals from resistance thermometers (RTDs). The two outputs allow connection of current or voltage actuators. The differential current and voltage inputs have 16-bit resolution for high accuracy.
The small size of the Sercos III Block I/O housing allows installation in small terminal boxes or in switch cabinets.
Bosch Rexroth Corp., 5150 Prairie Stone Pkwy., Hoffman Estates, IL 60192, (800) 739-7784, boschrexroth-us.com
