Straight compression fittings MCB-14 (brass) and MCB-14-303 (303 stainless steel) are only 53/64-in. long and designed with a 1/2-in. hexagonal body. Elbow compression fittings MCBL-14 (brass) and MCBL-14-303 (303 stainless steel) are 59/64-in. long with an installed height of 2 1/32 in. All fittings have O-ring seals in a variety of elastomers for leak-free installation. Benefits of the fittings include leaktight seal for tubing connections; 1/16, 1/8, and 1/4-in. OD tube sizes in straight, elbow and tee configurations; threaded fittings available with M3, M5, M6, 10-32 and 1/4-28 threaded connections, and Buna-N, fluorocarbon, EPDM, and silicone seals.
Beswick Engineering Co. Inc., 284 Ocean Rd., Greenland, NH 03840, (603) 433-1188, beswick.com
