New Products: Motor-Encoder Assembly
The unit uses ABEC7 class precision ball bearings and has a tightly toleranced hollow-shaft configuration for optical applications requiring a largediameter clear aperture. The high-resolution optical encoder supports resolutions of up to 0.02 arc-sec and its Hall-based commutation works with standard motion controllers.
BEI Kimco Magnetics
2470 Coral St., Bldg. D
Vista, CA 92081
(800) 572-7560
beikimco.com
