New Product: USB Flash drive holds 32 Gbytes
The rubber-encased Voyager provides durability against impact shock while the Survivor comes wrapped in a waterproof aluminum case with screw-on cap. The large-density USB 2.0 drives can be used as portable back-up devices for critical or sensitive information. They can also function as plug-in bootable drives that store different operating system versions. Each drive is bundled with a lanyard, preloaded security software/driver, and a USB extension cable. The drives are backed by a 10-yr limited warranty.
Corsair Memory, 46221 Landing Pkwy., Fremont, CA 94538, (888) 222-4346, corsair.com
