Power Supply Meets UL1310, Class-2 Specs
The Mini Power Supply is said to be the highest amperage rated, industrial grade, UL 508/1310 Listed, Class-2 power supply on the market.
It provides a 3.8-A (9-W) output at 24 V and ensures proper safety compliance with applications requiring a UL 1310 Class-2 power source. The device offers a wide input voltage range for ac and dc. Output currents are available with a regulated and adjustable output voltage of 22.5 to 26 Vdc with constant capacity above 24 V. It comes with a 3-yr USA warranty and more than 500,000-hr MTBF rating, in accordance with IEC 1709. It is DIN-rail mountable, fully enclosed, and has built-in diagnostic feedback via an alarm output. It uses pluggable, screw-clamp terminal blocks to simplify wiring.
Phoenix Contact Inc.
586 Fulling Mill Rd.
Middletown, PA 17057
(714) 944-1300
phoenixcon.com
