Scada Software
Monitor Pro V7.2 software is scalable Scada software based on a set of widely accepted industry-standard technologies, including ActiveX, COM/DCOM, OPC, and Microsoft Visual Basic.
It is compatible with Windows 2000 and XP. A built-in graphic interface provides a library of graphic objects that can be customized easily. Supplied with SQL Server 2000, the software records production data and provides fast access to stored information. Applications are stored on the Monitor Pro servers, but can be developed and maintained from any client in the system. Application modifications are pushed to all clients within the system, significantly reducing the cost and effort associated with developing and maintaining Monitor Pro applications. Scalability permits small applications to exist on a single computer, while large applications run across multiple servers. Additional scalability can be achieved simply by adding Monitor Pro servers in the middle tier.
Schneider Electric, 1415 S. Roselle Rd., Palatine, IL 60067, (847) 397-2600,
us.schneider-electric.com
