Modular Incremental Encoder
The ERM 280 modular incremental encoder consists of a scanning head and scale drum without an integral bearing.
The hollow shaft encoder uses a magnetic scanning principle for resistance to contamination, targeting machine design elements such as headstocks on lathes. The encoder operates with shaft speeds up to 40,000 rpm.
Heidenhain Corp., 333 E. State Pkwy., Schaumburg, IL 60173, (847) 490-1191, heidenhain.com
