Vacuum Conveyor For High-Temp Materials
The High-Temperature Line-Vac Conveyors are designed to move materials up to 900°F.
The High-Temperature Line-Vac Conveyors are designed to move materials up to 900°F. Air-pressure regulation provides infinite control of the conveying rate. The conveyor comes in five sizes from 0.75 to 2 in. in diameter and is constructed of type 303-stainless steel to resist high temperatures, corrosion, and contamination. Optional Type 316 stainless steel is also available. Target applications include sampling hot flue gases, exhausting fumes, and conveying soot, ashes, and hot debris. Other models for hopper loading, scrap trim removal, tablet transfer, and packaging are available.
Exair Corp., 11510 Goldcoast Dr., Cincinnati, OH 45249, (800) 903-9247, exair.com
