Low-Power LED Backlighting
A patent-pending light emitting diode (LED) backlighting technology targets hi-bright panels in outdoor signage, aircraft cockpits, and construction-site displays that need brightness levels of 800 NITS or more.
Jan. 11, 2007
The technology works with panels ranging in size from 5 to 19 in., from almost any manufacturer. A typical 15-in. panel retrofitted with the technology at 1,000 NITS, for example, uses only 24 W, whereas cold cathode fluorescent lamps of equivalent brightness require 65 W.
CI Lumen Industries LLC, 80 Davids Dr., Hauppauge, NY 11788, (631) 435-0035, ci-lumen.com
