Low viscosity epoxy
Dec. 14, 2006
EP30P, a transparent, low viscosity epoxy system has a service temperature range of -60 to 250 F, resists water, acids, bases, and salts, and can be used to bond, seal, coat, and encapsulate.
EP30P, a transparent, low viscosity epoxy system, has a service temperature range of −60 to 250°F, resists water, acids, bases, and salts, and can be used to bond, seal, coat, and encapsulate. It bonds with over a 9.5 kpsi tensile strength to a variety of substrates including metals, glass, ceramics, and many plastics. It has a 4 to 1 mix ratio by weight, a mixed viscosity of 1,200 to 1,400 cps, cures at room temperatures, and has a 6 month shelf life (at 75°F) when storeed in its original unopened container. The epoxy is available in pint, quart, gallon and 5 gallon kits.
Master Bond Inc., 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, masterbond.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
