Motion Control For Heavy Payloads
The ServoNut power module mates a high-performance NEMA-23 motor set directly on a zero-backlash precision ball screw to enable high accelerations of heavy payloads.
This unit is capable of 1 in., 300-lbf accelerations at 80% duty cycle as an example. The power module allows for speeds not normally attainable with ball-screw applications. With the power module, the screw remains stationary and the nut rotates to provide linear motion. This permits higher speeds, and longer strokes.
Bell-Everman Inc.,
82 Aero Camino, Goleta, CA 93117,
(805) 685-1029, bell-everman.com
