Product Spotlight: Speed Control I/O for Pump and Fan Motors
The device permits direct connection of small, 1-A, single-phase 120-V, 60-Hz motors. The terminal reduces energy use of capacitor, universal, and shaded pole motors as well as drives with quadratic load characteristics such as fans and pumps. Motor speed is specified by a 16-bit value. With the terminal, the motor is switched on and off with a mains synchronous pattern so the motor consumes less power.
Beckhoff Automation LLC
12150 Nicollet Ave. S
Burnsville, MN 55337
(952) 890-0000
beckhoffautomation.com
Related
Supplier Submitted
