Four-Terminal Wirewound Resistor
Sept. 15, 2005
Designed for low-resistance applications requiring high accuracy and temperature stability, the 10 Series of four-terminal resistors are designed for use in a Kelvin configuration.
The resistors have 1% tolerance, low inductance below 0.25, tinned-copper leads, and are RoHS compliant. Resistor values fall from 0.005 to 0.100 Ω with power ratings of 3, 4, and 7 W. Operating temperature range is from 55 to 275°C.
Ohmite Mfg. Co., 1600 Golf Rd., Suite 850, Rolling Meadows, IL 60008, (866) 964-6483, www.ohmite.com
June 27, 2025
June 25, 2025
June 25, 2025
