Power-line filter
The dual-stage Corcom EMC Series power line filter has maximum current ratings from 3 to 30 A, making it suitable for additional differential mode attenuation in low-frequency range while maintaining high commonmode performance, as often needed for motor drives and switch-mode supplies operating at higher frequencies.
Terminations available include Faston terminals, wire leads, or stud terminals for greater flexibility. The filters reduce noise to acceptable levels for equipment that must comply with U.S. FCC specifications and Europe's CISPR requirements.
Tyco Electronics
Box 3608, MS 38-41
Harrisburg, PA 17105
(717) 592-2409
www.cor.com
