Push-to-Connect Fittings
New push-to-connect pneumatic fittings permit instant connections by inserting a tube into the fitting.
No tools or other operations are necessary, and disconnection is just as simple. The fittings can be used in mobile and in-plant compressedair applications. They are available in a range of body designs and configurations in sizes from 1/8
to 1/2-in. diameter, in poly and nickel-plated brass versions. Push-to-connect fittings are also offered for metric tubes with BSP threads in taper, parallel, and metric forms.
Brennan Industries,
6701 Cochran Rd., Cleveland, OH 44139,
(888) 331-1523, brennaninc.com
