HG+ right-angle gearheads provide an efficiency above 96% with guaranteed backlash of less than 4 arc-min, ratios of i = 310, and an acceleration torque of 20 to 640 Nm. The single-stage hypoid gearhead also features low-inertia, high-speed operation, low noise, low heat, and compares favorably with servo worm gears and with larger two and three-stage gearheads with bevel stages. It mounts to servomotors in 5 min through a universal mounting system.
alpha gear drives Inc.,
1440 Howard St., Elk Grove Village, IL 60007,
(847) 439-0700, www.alphagear.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
